Really like this camera app for the X10, however can I set it that photos taken with it auto appear in Timescape? Alsodoes the phone auto store video / photos to SD card?
It seems to be an issue with vignette that photos don't show up in mediascape or timescape until you restart the phone.
Not the most helpful answer, I appreciate that but it must be something to do with either where it saves the files (although there is plenty of choice there and none of them seem to make any difference) or the file naming protocol that these two apps look for in live updates
If you open the vignette app and have the camera on, if you click the second icon down on the right of the screen, which should be the resolution, a settings page will be shown, where you can choose to save pictures in 'Vignette Folder', 'Default Camera Folder' or 'DCIM Standard Folder'. Hope this helps.
none of them make any difference (for me anyway) in relation to mediascape and timescape - restarting the phone makes them show up immediately
