Walkman 8.4.A.1.4 update
Johan
Master
A new version of the Walkman application has started to roll out. Version 8.4.A.1.4.
What's new?
-Added: Possibility to open detailed views
directly from Walkman® home
-Added: Possibility to go to Artist and Album from
any music item.
-Improved: Navigation menu user experience.
For Music Unlimited users, we've added "My
Library".
-Bug fixes and performance enhancements.
Please let us know what you think of the new Walkman update.
Tags (2)
78 REPLIES 78
Adik21
Plz increase the volume like Sony Ericsson mobile phones, it is the negative point of Xperia z1
BenGhasemi
The app crushes when I want to open Songs list, artists list, albums and... What can I do?
Johan
Master
@Henryadda21061997 wrote:
Update centre does not have any update for me please help! I have the old firmwares for all sony app only :'(
Please post the following info and I'll check if there are any updates available.
Model: (Found via Settings > About phone)
Build number: (Found via Settings > About phone)
Walkman version: (Found via Walkman > Settings > Version)
mt03
In Walkman There Should be a feature while sending any songs via any applicalation than all the songs should be visible. As I get songs list of only artists from which I have to select the song to send any third party application such as whatsapp etc ……………..I don’t get all the song drop list while sending audio files & its only gives the drop list of arrtis songs list ………………
TobbeWilson
Could you please add the possibility to set where to look for music!!!
I have asked for this a long time now and nothing happens, not even an answer.
As it is now i have all my ringtones, my whatsapp clips and my music visible as songs in Walkman, and i only want my music there nothing else!
And i cannot use the .nomedia file to remove it from Walkman, because that also prevent the phone from finding the ringtones.
bfc
Walkman sense me dosent work if i have to listen music through sense me i have to everytime update the whole music info once is fine but whenever you want to hear there is no music available on sense me please fix this
firebolt
I revert to Walman after SONY provides Folder Playlist on update 8.4.A.3.1.
Thaaaank yooou, SONY!!
Abhimanyu7
I am facing this problem of the scroll not appearing on the right side. I've been patient but this is really annoying. PLZ fix in next update. XPERIA ZL
groupama3
The option to multi select track in a playlist and delete them, currently the only way to do this is to log on to a pc, should be able to do this within Walkman also
G
