WCDMA reboot when activate data
alton38
My xperia X10i is rebooting in loop when WCDMA (only or WCDMA/GSM) is selected with data activated.
when i disable data or using GSM only, the phone still working but only with EGDE performance network Slightly_frowning_Face
I 'm in a new 4G LTE area, which start in same time as my reboot effect.
My phone is in android 2.3.3 with Baseband 2.1.71.
How can i fix it ??? I've tried format / wipe / etc ... but still not working Slightly_frowning_Face
Thanks for helping !
Sam
Legend
Legend
Have you tried running an actual repair as opposed to a rest?
To repair the phone software
1.     Install PC Companion on a Windows PC from Support
2.     Turn on the phone, and connect it to the PC using a USB cable.
3.     In PC Companion, under Support Zone and click Start.
4.     Under Phone Software Update, click Start.
5.     Click repair phone.
6.     Follow the on-screen instructions.
What are your thoughts about this forum? Let us know by doing this short survey.
