from the very first day when i bought my xperia miro i m trying to register in watsapp but it always say that check ur internet connection but i use bsnl 3g and it say reboot then as the moderator have guided i have uninstalled the app and again installed it but my problem wan't solved plz help
try to register using wifi
but i have working data plan ........
And internet works if you're using the web browser? If that's the case it might be due to some proxy settings by your operator. I know some operators have had issues with their proxy servers that makes logging on to facebook and similar services difficult. Try removing them under Settings > More > Mobile network > Access Point Names and try again.
What are your thoughts about this forum? Let us know by doing this short survey.
yes my internet works as a charm and i m even downloading apps............and ya have chnged acess poits and by the way my service provider is bsnl
Did you try to remove the proxy settings?
