Whats wrong with 2.1 ?
Hi i jus got my phone updated to 2.1 & m havin loads of problems now
1.the android keyboard is not suggesting words & in place of that showing my contacts when i type the matter
2.the facebook contacts not gettin along with my phone book contacts
3.The user guide has simply vanished
I belive was happy using 1.6 as its gettin really confusin now
Can't answer 1 as I use a T9 keyboard from the market
and 2 don't have facebook but for 3 you need to download a new user guide
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/restoretheuserguideinyourphone/xp...
Save it to your PC and rename it to emanual.zip then copy it from your PC to the folder on your phone called Other
There maybe teh old 1.6 manual still listed in there so just replace it with this one.
True, after 2.1 update, the keyboard doesn't suggest those words that we have already used. So hard to type again some big words again and again. Is there any ways to get it fixed or should we look for new keyboard?
Synchronizing contacts, I really messed my whole lot. I activated SE and Gmail, and I had 4 to 5 numbers for each names. All were duplicates. On its way, I synchronized Facebook, and oops!, the whole contacts got vanished and updated with facebook email IDs and names and blurred photos alone.
Had tough time to key in the whole 200+ contacts manually. The best backup is to backup in SD Card in PIM file format, and NEVER synchronize with online sites. They are better to view it online at times of need.
I upgraded to 2.1 and all went well at first. I notice that my screen would dim every 20 to 25 seconds and  the battery last have as long as it did with 1.6. Any Ideas?
