Hello! I have a problem with whatsapp,because at first receive msj..my notification light doesn't work...but when i receive 2rd msj..my notification light it's right
Please help me with this problem..
Thanks!!
Do you have stamina enabled?
no..i don't have stamina enambled..
Try to restart your device and check again.If still not working,contact whatsapp devs.
Have you checked whatsapp notification settings? do you have a third party notification app? do you have a taskiller or antivirus?
yes i check..but all things are ok...i dont have antivirus..or task..
Contact the devs from whatsapp.
