when i call appears the number and not the name
Pabl01
when i call to my xperia appears the number and not the name with he is listed
4 REPLIES 4
discretion1
Try clearing data: Settings-Apps--All apps--Contacts--Clear data. Reboot and see if the problem persists.
Sam
Legend
Legend
Is the number you are calling to the phone with attached to a contact in the phone?
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
JakeSully
yes like Sam asked the number has to be in your contact list that you then name it so next time that number calls you it will show the name instead Slightly_smiling_Face
Sam
Legend
Legend
As an addition to the above information, if the calls you and they do not show in your contacts list, once the call is complete press and hold on the number in the call log and choose "add to contacts". This will ensure that the number is added in the correct format to the contacts list to prevent this from happening again.
