When MR3 for Xperia X2 ?
We are waiting for a new bug fix release !!!!!!!!
AARON ?
Where are You ?
Answer now !
4 REPLIES 4
I'm also waiting for MR3..!!!!
lag, bugs., crash, freeze... when will these will be fix, i feel like using a cheap 10years-old phone, it so slow.....
I have a big problem,it happens once a day(it happend before MR1,with MR1,and with MR2). Cant unlock the screen,when I need to drag padlock left or right it just cant,padlock stays on the left or right side, I can get it back to the middle but unlock - NO (sometimes it promts for some ''unlock code'' but it is not usual lock code as I never set a lock code) and in mean while if you receive a call from some one he complained later on that why didn't you receive the phone, my answer is always that phone never vibrate or ring but when i check the miss call log the call was really there.
The only temporary solution is soft reset. Somebody have something to say???
Same problem here! n waiting for MR3! But they never answer to that qouestion!
