"Hello, i upgraded my xperia z1 compact from android 4.4.4. to android 5.0.2 on thursday. The update process succeeded without any problems or any error messages. It kept all my app data and at first everything worked fine. Wi-Fi connection at home was established instantly and worked fine with the authentication data from android 4.4.4. On friday i went to work and tried to connect to the university network eduroam with the same (saved) properties i already used with android 4.4.4.. A connection could not be established. Error message just said "Authenticationproblem"."
+1
I do not know the solution to your problem, but the same happened to me when I flashed my Z1 compact with customized FR 5.0.2 (usually I use customized CE3).
There was no problem with eduroam and Android 4.4.4.
With 5.0.2 I didn't managed to connect to eduroam for the whole 2 hours (or more) and I was trying every few minutes. Finally I walked around the building I work in and one router (one in few dozens we have) finally authorized me and I was connected to eduroam. I don't know what happened. At home 5.0.2 connected to my home router instantly.
I decided to revert to 4.4.4. When I tried to connect to eduroam again with that old version of firmware I succeeded to do so in the first attempt. Go figure.
Hi dk85
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Something likely to resolve this issue is a process called a software repair - it will reflash the operating system of your handset.
First install PC Companion for a PC, or Bridge for Mac for mac users. Once installed, open the program.
Running a software repair will delete user data
To back up your phone using PC Companion
1. Go to Support to install PC Companion on a Windows computer.
2. When installed, start PC Companion on the computer.
3. Connect your phone to the computer using a USB cable.
4. Click Start under Backup & Restore.
5. Follow the on-screen instructions.
On Bridge For Mac there is a Backup & Restore option there also that you can use.
Running the software repair
(Please ensure your phone is powered off and not connected to the PC during this process. You are not required to connect the phone until after step 10).
1. Install and open PC Companion then select Support Zone.
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
10. Follow the connection steps
Let us know how this goes.
This is not a solution to the problem. This is torture!
I re-installed 4.4.4 on my z1 compact and then upgraded it manually to another 5.0.2. firmware. This time it is Vipnet HR (Croatia). Today I tried to use wifi at the university and everything went well. I still don't know what went wrong the other time when I was trying to connect to wifi for 2 hours or more.
It remains to be seen whether I will have some problems with wifi with this firmware.
It is very time consuming to try out all these firmware versions. It is not my job to test firmware.
I have a problem were after a few days, I start getting authentication errors reported, and the phone stops connecting to the wifi at home. I have to restart it then enter the password again and it connects. The phine is three years old, and this never happend prior to the update. As well has there not have been any changes to my wfi. It looks like a bug to me.
