I wet my sony xperia arc s. All is working ok except the wifi ( I can connect it but the mobile doesn't find any wifi) and the bluetooth. Any ideas if it is possible to recovere these funcionalities? Thanks.
If the phone has been exposed to water/moisture the antennas for Bluetooth and Wi-Fi might have been damaged. I suggest that you contact your local support team to check if this can be repaired at all.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
