X alert password reset ??
kbiswas
Hello Sir,
I have a Sony Xperia Z1,I forgot the Password,how can I get the Password?Please help.
Thank you.
Regards Sujit K Biswas
Thommo
Genius
You can't you need to perform a system repair which will erase all data - This is due to security reasons
AakashRai
Hi All !
Anybody have a solution for how can reset password of X-Alert. I'm tried to find out the way to reset X-Alert password.
Please suggest if anyone have solution.
Regards,
Aakash
xavinux
Enthusiast
Hi @AakashRai
Have you try this ?
1. If you have Screen lock = Pattern then you need to change it to PIN
2. Go to Settings => Security => Device Administrator and untick X - Alert for XPERIA
3. Now go to Settings => Apps => All = Select X - Alert for XPERIA
4. Click on Force Stop and do Clear Cache
If my answer was helpful for you, please thank me with Kudos.
I'm at disposal for any question.
Best Regards,
