Xperia can't detect SIM card from anotar country
Heidji
Hello Everybody!
This is my first experience with Xperia.
I received as a gift, a Xperia Z2 unlocked from USA BUT I'm trying to work with a carrier from Brasil, but the simcard isn't detected and if I put a Metro PCS simcard the Phone works.
In my SIM CARD lock status shows:
[ ] Network 0
And bootloader unlock allowed yes.
Anybody can helps me if its possible to work with this Phone in Brazil?
Cause I didnt found a solution.
7 REPLIES 7
Uliwooly
@Heidji
It'll be wise to get a brand new SIM card from your carrier
Heidji
Hello @uliwooly ! I tried to use another sim card from other Brazillian carrier and I still with the same behavior
Uliwooly
@Heidji
Are you 100% sure that the phone was unlocked ?
Could you try a brand new SIM card? make sure to get the right size and not cut/trim it
Heidji
uliwooly,
The information that I got and assures me that the phone is unlocked, is the inrformation of SIM Lock Status = [ ] Network 0
I don't have one thing more than this Flushed_Face
I've tested with a brand new nano simcard with adapter, and a micro simcard that works fine on Iphone 4s.
I looked for a local support, but they recommends me to try a hard reset by PC Companion, but I've tried. And they sad that the phone doesn't supports my local carrier, but hey didn't know about my current carrier.
The information that I got, Brazillian carriers works with 700Mhz (Band 28), 1800 (Band 3) and 2600Mhz (Band 7).
profile.country.US.title
jmaxim917
The Z2 was never released in the US so it's not a Us model. What's the model number of your phone? 6503, 6502 or 6543. Check the link below, there is a link on that page to the white paper which will provide model specific bands.
http://www.sonymobile.com/global-en/products/phones/xperia-z2/specifications/
Hope this helps.
Heidji
Hello!
The model is D6503.
What is the better way to confirm that this phone isnt work in Brazil?
Heidji
Hello guys!
You know if the pattern of polarity makes difference for the sim card detection?
http://imgur.com/CGB1Cr5
