Xperia Go Screen Protector
IamDante
Should I use a screen protector paper on my xperia Go??
Sam
Legend
Legend
That is a personal choice, though the handset does have its own pre-attached shatter proof sheet.
What are your thoughts about this forum? Let us know by doing this short survey.
kris1414
well, as Sam just said. personal choice, however pls note that some people have problem with their proximity sensor if the screen protector is covering the proximity sensor. it would be wise if you could apply screen guard which has been designed to x go or maybe you could improvise a bit by cutting to uncover the proximity sensor..
