Xperia ion LT28h problem
Hari_22
In my device (Xperia ion LT28h) update for the device was intimated. I started the update using wifi in my home by using a sony companion software. In the middle of the process, it intimated to unplug my device and so i removed. From that moment my device just shows SONY  in a blinking manner. And the small blinking light glows and my mobile does not boots.
Kindly help me:smileysad:
profile.country.RO.title
_alexdon_
You have to perform a software repair using PC companion.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable.
alexdon
