Xperia keyboard missing clicking sounds
Mithun6193
When the keys on the keyboard is typed moderately fast the keys are missing their clicking sound. Is anyone else having this issue?
13 REPLIES 13
Uliwooly
@Mithun6193
Just like your other issue, could you test it on >>> safe mode
using which apps do you encounter this issue?
Mithun6193
This is happening wherever I use the sony keyboard, I also tried on safe-mode but the issue persists
Uliwooly
@Mithun6193
with all apps?
Mithun6193
Yes
Mithun6193
I just installed Google keyboard and it also had the missing keyboard click sounds, is this a problem with my phone ??? Or does anyone else have this problem on marshmallow version of Xperia z3+. If so please do reply.
Mithun6193
Suddenly, from today morning the keyboard click sounds have returned to normal they are working properly. I just wanted to give you an update.
Uliwooly
@Mithun6193
Glad to hear that it's working
Mithun6193
Update, Till 21st may the keyboard sounds were working perfectly, but at 9:45 pm the sounds started to go missing again, and in the period of the 5 days, it worked perfectly I had no issues with that. ( I didn't update software nor did I install anything new.) is there an explanation to this erratic behaviour of my phone.
Uliwooly
@Mithun6193
since it's an erratic behavior it will be hard to narrow down the cause.
