Hi, I bought xperia P 10 days ago and were completely satisfied with it and the battery life was also decent, but two days ago while charging my phone it started discharging, since then if I do something with my phone when plugged in it begins discharging and after a while it starts charging again. and since the day battery life shortened dramatically, it lasts about 6 hours with normal usage (yeah I have turned off wifi and almost every discharging app).
please tell me if someone had same issue, Is my battery spoiled? one more thing, I tried system repair but that didn't help either.
same thing for me..waiting for the answers from our mates..lets trying charging it while phone is off..
I may have found the reason. Yesterday i accidentally broke my sim card which i was using, but the card wasn't micro sim card it was an ordinary card which i had cut to a size of microsim, so i had tu replace it and i bought micro sim since then my battery is same as it was at first and never discharges while connecting. I don't know maybe it's coincidence but it worked for me. Do you have an original micro sim? Or you've cut the big one?
you can do two things
1.wait for J.B update and see if it resolves ur issue
2.get ir repaired from service centre..
now its upto u .. if ur area sony servce ppl give good customer suport than u shuld go and get it fixed.
do u try to update ur phone via sus
I am using a cut simcard. Im the one who cut it haha but its nice that you fixed the issue
