Xperia P with Viber, Messanger and WhatsApp
ivok88
Hello "dear" Sony !
I want to know is it possible to make something to my "phone", to use it like a SMARTPHONE!? My bootloader is locked and is impossible to be unlocked, so i want to know how can i repair it to use it like a PHONE? It has been given for repair in garanty 8 times because of the software! When i install viber, FB messanger and whatsapp it is lagging on calls, apps and everyting. It is just existing, not doing any work of all. If i wanted a phone without viber, messanger and whatsapp i was going to buy some nokia 3310 for example. DO SOMETHING TO YOUR BUGGY SOFTWARE!
HAVE A NICE DAY!
jackxperiaP
As u couldn't unlock your bootloader jus root your device and install cwm and then install a custom rom .. mostly custom roms for xperia p have solved the call lag, unresponsiveness etc.. but viber is always a prob i guess .. now i use messenger, watsapp, skype and no prob at all if i put the default notification sound to silent or else no sound ll be heard aft few mins ,,
