xptoday i noticed my phone is running extremely slow so i decided to look at the memory found out the phone was eating alot of it. so my next action was uninstalling apps to which i did and still did not make any difference eventually i attached it to the computer and it was reading that my memory is full and only 1.29gb is avalible, which got me thinking i do use the phone alot for pictures and when i send it over whatsapp for some reason it duplicates the picture which is very shocking i have had a look through all the folders and added them up and it reaches to 5gb max? so what could this problem be and how can it be resolved i really dont want to format my phone as it is annoying.
try to disable your sync with that app, check the settings
