My Sola's screen is flickering whenever screen display white in behind, example during browsing or reading, you can try the steps below see your Sola having the same problem or not:
Anyone having the same problem? Any solution? or should i send back to change a new phone?
please advise, thanks!
i think thats the light sensor from the phone.. if you set to auto brightness and your brightness level is low, you will see your screen kinda flicker.. if you notice theres there are a few small circle thing at the front of your phone. if your finger is blocking the circle thingy, the screen will adjust brightness by itself. im not sure if this is your problem but hope it helps. try not to set your phone to auto brightness
Yes, i believe it's related to the sensor, but even i turned the Auto-Brightness off, the flickering still occur.:smileysad:
Hav u tried tirning auto brightness off amd set the brightness higher? If not try repair ur device using pc companion. Backup ur stuff 1st.. This reminds me of my mini pro, same thing happen with the screen flikering.. And the capicitive button started flicker as well
I turned off Auto-Brightness and set the brightness to max, still flickering occur. So i decide to bring back to the shop and change a new one....
so you got yourselve a new sola? by d way, do u experience any laggyness whn u charge your phone while using it? example difficulty in swiping through home screen?
not yet, waiting the new stock arrive, hopefully won't have the same problem
laggyness? nops, it's run smooth as silk :smileysilly:, i'm very satisfied with the phone except the flickering screen, nice phone with this price.
ic good luck to you man, i bet its allrite. because mine has got no prob with flickering screen but with charging+not so smooth prob..:D
Status Update: I manage to get my Sola replacement unit in Black, no more flickering problem (so far
) and love it very much!
wow ur lucky.. i brought back to the shop and she told me to bring to sony centre.. u bought yours at sony centre?
