Xperia X10i battery life too short
Hello All,
I bought brand new X10i . then make full charge before use. I just to test see how long battery . In first day, I use only 5min calling. Then put aside, battery down 50%
Second day (whole night charging) , I don't do any thing. Only call for 5min In the afternoon, battery 0%.
How could they say 5h talk time ? And 140h stanby?
Cheating ?
Martha-
Battery life is something that has been discussed here quite often.
I suggest you start in this discussion here http://talk.sonyericsson.com/message/36387#36387 and see what you can get out of it.
In the end, if you determine a problem (with the battery or the phone), your best option is to call us locally, or return to the store.
The truth is the battery willl only reach it's quota if you disable everything.
