Xperia Z1 backing up notes.
H4rry
I have lots of notes save on my xperia Z1 these are on the standered notepad that comes with the phone.
When I use backup and restore will these notes be saved with contacts etc to my pc?
I cannot find any way to foward them to email etc and there are too many to be typed out again.
5 REPLIES 5
Uliwooly
@H4rry
Other users have asked the same question, the notes will be gone
H4rry
Ok thanks for the info.
This latest firmware for the z1 has been a disaster to say the least I think my next phone will be made by someone other than sony!
Uliwooly
@H4rry
What seems to be the issue or issues?
if its a battery issue, reinstalling lollipop (clean update) will fix it, also keep in mind that lollipop its a LOT heavier than KitKat and will drain your battery faster, that's not a Sony issue but rather an Android issue, you can google Android Lollipop ART
profile.country.RO.title
_alexdon_
You should be able to send them via email or upload them to cloud. Go to notes app,tap longer on one and select those that you want to save. Then tap the share icon.
alexdon
H4rry
Issues are the mic breaking up was the first thing that was noticed when people told me they could not make out what I was saying.
Internet has become very slow battery drain would be the main problems.
I'm not going to update my xperia tablet it can sit as is as long as possible.
