Xperia z5 premium laging
Mahmmoud0114454
Hi guys..
I heard from my friends that sony's phones don't lag like samsung or rarely lag so I bought Xperia z5 premium dual I just have it for 2 months I noticed rarely lag of some apps and now I experinced lag the phone and no responds even when I tried to mode to another app I opened on tasks no responed so please any help in this or why that happened
7 REPLIES 7
YoGem
Leader
Did you install some apps that are always on? The lag on such kind of devices it may be just due low ram or intensive CPU usage. You may first of all trying to reboot your phone in safe mode, if when in safe mode the phone won't lag, reboot to normal and start to uninstall all the recent apps one by one until the phone stop lagging, or use XC and repair your device.
CameronT
Champion
Hi @Mahmmoud0114454,
Lag is generally caused by third party apps that are running in the background.
You can test this by putting your phone into safe mode. If it is not lagging in safe mode, it is going to be third party apps causing the issue.
Mahmmoud0114454
And how I should what app making my phone lag
Mahmmoud0114454
@yoGem
Its lager for seconds and become normally so why to uninstall my apps?
Jake-SonyXperia
Champion
The reason you remove the app is because it may be causing strain on the handset and its resources. Unfortunately finding which app is causing the problem is the hard part and takes time.
Mahmmoud0114454
Hi guys..
My phone just lag no responding and when I tried to lock the screen and reopen it also norespond and the screen go on with pale colors and then the phone restart by it self I tried safe mode no problem but just to know this happens for the first time so anyone can tell me what is the problem
CameronT
Champion
If the device is working correctly while it is in safe mode, then it indicates the issue is being caused by a third party application.
You can try removing apps one by one, starting with the last installed app and moving back.
Or you can simply start everything fresh with a software repair.
