Guys, i have observed thise problem for a week now and i wanna report here to see if anyone of you having the same issue.
My Xperia Z mobile signal (3G,LTE) is not fucntioning, sometimes i can see it is connected to 3G or LTE but no data flow. Sometimes it was just full bar on the mobile connectivity but without 3G or LTE. I have compared my Z to the other phone when this thing happened at the same time and the other phone seems to be ok. I off location WIFI all the time. Sometimes i restarted the phone then was ok.
I wonder if this is a phone or carrier problem, but my other phone is using the same carrier as well.
Please help. Thanks.
do you have a micro SIM card or did your trim a regular SIM card?
the problem might be a faulty micro sim card or it could also be an app acting up
uninstall any
taskillers
antivirus
battery apps
ram apps
also double check the APN settings
Don't forget to mark the Correct Answers & Helpful Answers
you can also repair your phone with SUS or PCC
SUS
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
