Z1 compact battery
Vicster2803
Z1 compact battery
I am having a problem with my z1 compact...if I have the phone display on for longer than 2 minutes, the phone shuts down and won't switch back on unless connected to a charger. When it does switch on, the battery percentage is usually around 60 percent after only 5 minutes of charging. Sometimes it optimises applications which can take up to one hour.
I have tried resetting and I have connected to pc companion and repaired from there.
Any ideas gratefully received 😊
7 REPLIES 7
Uliwooly
@Vicster2803
That's clearly a hardware issue, contact your Local support to get it inspected and/or repaired.
SergioPL1
If you are in warranty period try local Sony support. If out of warranty think how much you value water proof, and then make a decision to service through official channel or your nearby mobile service. In PL battery replacement in Z1C takes around 1 - 2 hours.
I had this issue in Z1, my friend just replaced battery in Z1C... same as in yours. 40 to 60% of battery, then steep discharge to 1 -2 % within a second and immediate shut down.
Ivan013
HI. I having the same problem. Did you find a decision or only the change of battery will help?
slipd
Hi guys,
Sorry, this thread caught my eye: having problems with the battery drain issue and it seems to be getting worse! Currently switches off at around 25% Slightly_frowning_Face
Very annoying... I was just wondering, a.) how easy it is to fit a new battery? (Genuine Sony batteries on eBay for less than £10) and b.) if a new battery will make any difference whatsoever?! I'm out of warranty, purchased Jan 14' so I have nothing to lose as such. I was hoping to keep my Z1 Compact going until 2017 but at this rate I may have to consider upgrading early.
Be a shame to because I really like the phone :smileysmileythumbsup:
SergioPL1
@slipd wrote:
Hi guys,
1) Phone is glued to keep in water proof. If you think you can manage it you will easly find some guides on youtube. If you are not sure (easy to break the glass) handle it to pros, who will do it for you for a little charge.
2) After replacing battery everything worked normal.
slipd
Thanks, I think I'd probably supply to the parts and get a professional to do it. Are you saying that a new battery resolved the issue in your case?
I worry that this issue in general might be this Lollipop problem that keeps getting banded about. Apparently it is fixable but Sony aren't because the handset is no longer supported. Some of the modded firmwares (5.1/6.1) are reporting the problem as fixed!
SergioPL1
I heard a lot but on mine Z1 I encountered that problem before Lollipop roll-out.
Second, friends Z1C - it is unbranded, working under 5.1.1 and after battery replacement it works fine. Maybe fixes that you mention are fixing it the way it doesn't shutdown immediately from 60% to 0% but it just drops down faster, in more linear way. Anyway if battery runs out of juice it will die.
My wifes Z1C is now 2.5 years old and still working fine on original battery but she charges it every two - three days. For me it took around a year of everyday charging of Z1 to observe this problem.
