I jumped into pool while the pgone was recording, before that i checked all the flaps and double-checked, and they were all sealed.
so i jumped in and the phone was fine. got out and started recording again (phone ws still fine) then i left it on a table, came back after around 10 mins. and lo and behold the phone was off and wont turn on .
i removed everything. sim nd micro sd. and saw some water on the sim, but why??
i checked and double checked all the flaps.
after that i put the phone in a bag of rice and left it for a day. after that i charged it and the LED flashed red, then blinked blue. then red again.
what do i do?
the red LED blinking then 3 Vibrations doesnt happen anymore. so i think its not the water anymore.
Help!!!!
my xperia Z1C's screen wont work
but the phone still works.
like the LED still works. and i can still hear the notifications like the battery low notif and the usb unplug sound.
so its like the screen just wont work.
please help.
Could you try to force a shutdown/restart of your device by holding down the ON/OFF + volume up(+) button for 5-10 seconds to see if this can help?
HI Hampus,
Yeah i already tried that but didn't help. the screen still won't work.
thanks anyway
Well, based on your previous posts I think you would do best by visiting nearest service center to have the phone examined by a technician. You can contact your local support team for further information about how to proceed with this in the best possible way:
http://support.sonymobile.com/global-en/contactUs/
ok Thanks!!!
and thanks for the fast reply!
