Z5 compact Volume turns itself up when on vibrate
Lins81
Hi
I have my phone on silent/vibrate quite a lot when I'm at work but I do still use it. However, sometimes the sound turns itself up a notch which isn't ideal as when I receive messages etc I get the message tone as well. Is this a problem with my phone or is it something to do with me using it whilst it's on vibrate ( although I'm pretty sure it should be ok to use??). I am using a Z5 compact.
4 REPLIES 4
Uliwooly
@Lins81
Let me see if I understood, are you saying that the notification/ringtone volume turn itself up/on even if you have set the phone on vibrate mode?
Or
Are you referring to Media(Music) volume while on vibrate mode and receiving notifications?
Lins81
@uliwooly wrote:
@Lins81
Or
"Let me see if I understood, are you saying that the notification/ringtone volume turn itself up/on even if you have set the phone on vibrate mode? "
This is the problem. It doesn't happen all the time but if I lock and unlock my phone a few times it tends to happen.
thanks
dandy63
Leader
@Lins81 try running your phone in Safe Mode for a while, this will rule out a 3rd party app possibly auto adjusting your volume
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Ryumyo1
I experience a similar problem as well. When I set the media Volume down, after a while it jumps back to where it was before. I will try to gather more information about when this takes place.
