So far I'm very happy with my Z5 Premium
BUT
why can't Sony provide a SW where you make use of the higher resolution and big screen.
The icons etc just get bigger - everything is blown up - and that's it. What a shame and very annoying.
Basically its a Z5 with a magnifying glas.
If you look at other smartphones (ie iphone 6 vs. 6 plus, S6 edge vs edge+) you get more icons on the home screens, you see more mails in the inbox etc.
Hope they do something here with a future SW update.
You can use a third party home launcher and other apps to customize your phone as you please.
That used to be the case back with feature phones (dumb phones) but now with smartphones you have myriad options, as far as the other apps, you can use the Gmail app with non-google accounts, also
settings > apps > select the app > disable > download another app that you prefer to use google calendar its quite good.
Thanks for the hint but the problem is that the icons become smaller but the gap between them bigger => not more icons to be placed
