I can't change the volume of my alarms on my new XZ1. When I go into the settings for each alarm there is no volume slider. How do I sort this out?
Solved! Go to Solution.
There IS a setting to adjust alarm volume in all Xperia phones.
The OP had an app interfering with this setting.
Hi @Namremmiz, welcome to our forum!
As @Quester wrote, you can of course change the alarm, ring/notification and media volumes in all of our devices. Why it was not working for @GabrielaMelo was because he/she had a third party application installed in the application that caused this behaviour, but everything is now working again.
I hope that helps!
Can someone please give me instructions on how to find the volume setting? I can't find it on my phone
Don't understand your doubts, just go to settings >Sound >Alarm volume, or directly press the volume up or down key >down arrow on the right hand side of the screen and use the alarm volume cursor. You even have an option on the "more settings" of every alarm to increase volume while ringing.
Thanks, I have found it now. I was previously looking in the settings in the alarm function area
