android wireless car
-Maryline-
good evening everyone,
I would like to know if XZ2 is compatible with android auto wireless connection with my vehicle which is ready to receive it.
This type of connection is not widely used on smartphones, whereas newer cars are equipped with them.
thank you in advance
cordially
android auto sans fil
bonsoir a tous,
je voudrais savoir si  XZ2 est compatible avec android auto connection sans fil avec mon vehicule qui lui est pret a recevoir se systeme .
se type connection n a pas l aire tres repandu sur les smartphones alors que les voitures recentes en sont equipées.
merci d avance
cordialement
Uliwooly
@-Maryline-
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Do elaborate on the question.
