Apps not working after Android O update
hareeshreddy
Today I updated my XZ Premium to Android O and suddenly some of the app (such as Instagram) is not functioning properly. When I will try to open the app at the startup it only displaying a white blank screen and after few second closing itself automatically. I am having similar issue with few other apps as well. Anyone facing this same issue after the update can anyone help me to fix it asap?
___________________________________________________________
Tutuapp Showbox Tutuapp
hareeshreddy
Just a quick update guys! Apparantely after I deleted the instagram, restarted my phone, and reinstalled the app it started working fine again. Maybe app compatibility issue with Android O.
hareeshreddy
