Since i updated my Xperia XZ Premium to Oreo 8.0.0, i can't find my TomTom tracker anymore.
Anyone have same problem?
Please SONY, fix that bluetooth problem!!!!
On any Android 7.0 phone, tracker can be found
Please help!!!!!!!!!!!!!
keutschi
@keutschi go to Settings > System > About phone and tap Build number entry 7 times. then go to Settings > System > Developer options, find entry named Bluetooth AVRCP version, change it to 1.5 and see if anything changes. if you still can't connect to the tracker, try setting it to 1.4. you can try rebooting the device after every change for a good measure.
Thanks, but no chance to find TomTom Tracker with Oreo 8.0.0.......
That is TomTom app problem not Sony's, and I suggest you contract TomTom App developer at Google Play store.
