after update Android 7.0 my XZ can't connect properly to my car via bluetooth. The telephone connects, but the media connection try to connect contiously but do not reach to connect. I can't use my XZ in the car, because battery runs down very fast due to this bug. Is there a fix? Have anyone the same issue?
try to perfrom a software repair using Xperia Companion
re -pair both devices,
contact your car stereo manufacturer if they support compatibility with the nougat update
I have the same issue. Plus no contact to phone book and recent calls. one week ago with 6.xx everything worked fine.
I'm having also troubles since last week when I got the android 7 update.
Both my bluetooth headsets the SBH54 Sony isnt responding on the buttons, also not on the musicplayer.
And the free headset MDR XB950BT isnt working either anymore.
Also got the advice from sony to use the repair with the Companion Software, and making a backup.
The backup with Sony Companion didnt work. However the one on my SD card luckely is.
And the second option is sending the phone back. But now i'm reading this already, i think that sony should make a new update.
HI!
Just got an android 7.0 update today and after the update my bluetooth is not working anymore...can't turn it on
How we can fix it?
My phone connects and music and calls come through, but the car audio system says "device not connected" and won't show track names or any other song information.
You may need to open the car related app and re-allow permissions to access contact, folders, etc. I had to do this with the Audi MMI app, and then the car would show contacts, etc,
