How will it work? There is no dark mode on xz 1 compact after update to pie 9.0
Solved! Go to Solution.
Thank you so much I now have the normal version back again!!! 😁😁😁😁
@najodleglejszy, thanks for helping out!
@Johnny1975, awesome!
The developer options is something that Google provides and is mostly there for developers. I'm not an expert on this menu since we don't really support it, but I'm glad to hear that it works for you now at least!
I set it to Always On.
Will test it the next week and see which apps are in darkmode now.
THX.
I've all my devices in darkmode.
