Dialer shows ads
Enkel
Dialer shows ads
After a call, a popup shows the Number and some Details to the call, but two third of the popup is an advertisment.
The popup eben doesn't disappear after a while but need to be closed manually.
My questions are:
How can I
*) remove Pop up permanent or at least
*) geht rid of the Ad.
I bought my telephone and don't need ads within pre installed apps.
I disabled as much as I could of pre installed apps, as I'm not interested in bloatware, advertisments and so on.
But to implement advertisments in the dialer is kind of dodgy.
I hole to get an answer soon
BR.
Enkel
HikariKobushi
It is very strange issue you got there. My first thought is didgy app that you could install like "booster", "cleaner" or "battery saver" kind of thing. My XZ1C does not give me any pop up adds so either it is made by bloatware installed by your provider or dodgy app that you downloaded.
If you will and you like things like flashtool you could flash clean firmware onto your Xperia.
Jonas
Master
Hi @Enkel, welcome to our forum!
It does sound like you have installed some application that does a search for the number that is calling you or something similar as none of the pre-installed applications have this kind of feature.
Could you try restarting your device in safe mode and make a phone call and see if there is any change?
Let me know how it goes!
Enkel
Thanks for your reply!
The mentioned Feature does Not come up ever time I habe a call.
Attached you can find a picture showing the Pop up. I have removed greater parts of the number i had the call with.
I will stay in safe Mode and will try if the popup come up.
Best regards!
 Anton
