Hi, recently my Xperia XA1 Ultra phone has been freezing when I try to end a call. I can successfully press the end call button but upon doing so, the screen freezes and doesn't actually end the call. The screen is not black or anything.
If I try to make another call, it doesn't let me and instead prompts me to return to that call in progress that doesn't actually finish. I have to restart the phone to fix this. And until I do restart the phone, I am unable to receive any calls or text messages.
I checked and my phone tells me I am fully up to date.
Any ideas on what could be going on?
Thanks!
This is a common problem on any Xperia, sadly its found only on Xperia devices but Sony doesn't want to admit it or try to fix it.
The problem is
Basically if you are on a call and receive a missed call from another person at the same time.... That's it..you can't make a call to that person . Phone will freeze.
Yes the only way to get it work is to restart the phone itself.
I think this issue actually goes deeper than that, as it happens basically every time I finish a call (including to voicemail). The odds of receiving a missed call on every one of those seems very low!
Safe mode actually does seem to work! In that case, is the solution to just start deleting apps until the problem goes away?
Well it just freezes in safe mode too
Either that or start fresh by performing a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup.
Install your apps in small batches and observe if the problem appears.
Thanks! I'll do as you suggested and either report back with results or accept your suggestion as the solution if indeed it solves it. Thanks again!
The problem is Sony will never fix it. Their repair engineers are too poor to identify the issue. May be too much trainees
@Jr8 wrote:This is a common problem on any Xperia, sadly its found only on Xperia devices but Sony doesn't want to admit it or try to fix it.
The problem is
I dunno but I never witnessed this issue on ANY of the Xperias I owned, which are plenty.
