Google apps are always changing display color tone on XZ3 Android 10
profile.country.SI.title
dsxyz_
Hey,
always when when I run some google app is this changing my display color tone.
I have display set to standard mode and then when I use some google app, this app changes display color tone. Then looks like Super-vivid mode and display is still set to standard mode.
Then I have to always change display mode to get back to standard mode.
Thanks for your help.
Tags (3)
chesda
I also had this problem and fixed it by disabling dynamic colour gamut within Chrome settings.
  • 1. Enter “chrome://flags” in the address bar of Chrome.
  • 2. Find the Dynamic color gamut (enter “Dynamic color” in the search field and it will filter the setting)
  • 3. It is set to “Default”, change it to “Disabled”.
  • 4. Relaunch Chrome
chesda
IamNic
Hi @chesda,
just for the google results - it works with the Xperia 5 as well, presumably also with the m2 and the Xperia 1 of course.
- Nic
dsxyz_
Hey,
I have tried now disabling dynamic colour gamut within Chrome settings and it's working.
Thank you!
