How to make the music player appear on the screen
Brendis
Como puedo poner el reproductor de musica en la pantalla, para no estar entrando a la aplicación
How can I put the music player on the screen, so as not to be entering the application
-GT
Jonas
Master
Hi @Brendis, welcome to our forum!
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
Which music player do you use? If I understand correctly, you want a widget on the home screen where you can control the music and not opening up the application to, for example, change track?
Depending on the application that you use, the developer may have added a widget and you can add this to the home screen if you press and hold on an empty area of the home screen > tap on "Widgets" in the bottom left corner > scroll to the right and see if you can find one for the application you use.
I hope that helps! Slightly_smiling_Face
Darksteel165
This is correct. Also the Xperia built in music app does in fact have its own widget. No thrid party app required.
