I used the 'transfer to SD Card' button in storage and now cant find files on SD card
WildeMega
Hi all,
My XZ1 came up with a notification to say my storage was low, did I want to transfer some files to SD card, so it took me to a screen where I could select photos videos and files (but couldn't see which files it had picked) so I did it and it transfered some -
I went back to my album to find the photos and videos I had taken the day before and the day of were gone.
Went onto 'files' and my SD card to look for the transfered files, and now, I can't find them on the SD card anywhere, it's like they have vanished.
Any idea what folder they would have copied to on the SD card?
Thanks!
Leslyy
Have you had any solution? It happened the exact same to me. I just chated with sony support and they basically said to me that there was no remedy, because seemed like it was an error from the android system.
