Many errors with the update of oreo
julio87
Many errors with the update of oreo: the phone gets too hot. The light of the screen is very sensitive in automatic. Many applications work badly in oreo, notifications are not received. Thank you
Valeque
I`m a "happy" owner of the XZS version of phone, so decided to add some more info.
Also the backround is faulty: if you watch video on youtube and press the on/off button, then after the screen comes up again, the last frame from this video will appear as the wallpaper. And sometimes when the screen rotates it saves the wallpaper orientation in the middle of rotation and it sows only the corner of the wallpaper while the remaining of the screen becomes black.
Bluetooth: Every time it connects to my car(toyota touch 2) it gives me an error notification and tries again with the same result.(tried already to switch the BT versions 1.4-1.6 without success)
Apps: many of them shuts down without startin.
Backlight: waaaay too much light sensitivity.
Nexus11
Hej har beta Oreo 8.1.0 fick en system uppdatering men något blev fel för ett tag sedan och efter det så går det inte att uppdatera den igen.. varför inte?
Hello, the beta Oreo 8.1.0 got a system update but something went wrong a while ago and after that it's not possible to update it again .. why not?
GT
