SteadyShot™ with Intelligent Active Mode (5-axis stablization)
4K video recording
HDR photo
Front camera
13 MP
1/3.06” Exmor RS™ for mobile image sensor
Low-light photo: up to ISO 6400
22Mm wide-angle lens F2.0
Networks
GSM GPRS/EDGE (2G)
UMTS HSPA+ (3G)
LTE (4G) Cat 9
Connectivity
A-GNSS (GPS + GLONASS)***
Wi-Fi Miracast
Bluetooth® 4.2 wireless technology
DLNA Certified®
Google Cast™
NFC
Fingerprint sensor
Fast and secure unlock
Sound
High-Resolution Audio (LPCM, FLAC, ALAC, DSD)
DSEE HX
LDAC
Digital Noise Cancellation
Clear Audio+
S-Force Front Surround
Stereo recording
Entertainment
PS4™ Remote Play
Key accessories
Style Cover Touch SCTF10
Style Cover Stand SCSF10
Quick Charger UCH12W
USB Type-C Charging Dock DK60
High-Resolution Audio Headset MDR-NC750
Disclaimers
* Memory comprises approximately 12 GB of firmware, plus 20 GB of “Internal storage” for music, pictures, and movies, and downloaded applications and their data.
** Xperia XZ is water resistant and protected against dust, so don’t worry if you get caught in the rain or want to wash off dirt under the faucet water, but remember all ports and attached covers should be firmly closed. You should not put the device completely underwater; or expose it to seawater, salt water, chlorinated water, or liquids such as drinks. Abuse and improper use of device will invalidate warranty. The device has been tested under Ingress Protection rating IP65/68. For more info, see www.sonymobile.com/waterresistant. Note the Xperia XZ has a capless USB port to connect and charge. The USB port must be completely dry before charging.
*** This service is not available in all variants or markets.
