Missing track info when using XZs in car with bluetooth connection
Blotz
When I use my XZs in my car by bluetooth connection I don't see track info, it just show "unknown".
Also the commands play, stop, forward don't work. The software of my entertainment system hasn't changed and my Z1 with android 5.1 worked great. My XZs with 7.1.1 doesn't. It doesn't matter which app I use, Sony music or Google Play.
Would be great if this can be fixed.
Blotz
After apgrade to Oreo the following solution works in my case, I set Bluetooth version to 1.5
  1. Unpair both devices from each other.
  2. Go to Settings -> About phone -> tap multiple times on "Build number" until you enable "Developer options"
  3. Go back to Settings -> Developer options -> Networking -> Bluetooth AVRCP Version -> Choose AVRCP 1.4 or 1.5
  4. Restart your phone
  5. Pair devices and test.
profile.country.PH.title
MarlonUk1
this is a known problem with nougat, not just in sony devices. have you tried to contact the car stereo maker to see if they have released an update on their side?
Blotz
Thanks. I have contacted my car stereo maker, Audi. They didn't had an update/solution. Maybe in the future. Hope android fixes this in future release....
Blotz
