no notifications fb messenger
DiamondHeartVix
I'm not getting notifications of fb messenger messages. I've checked all the notification settings on both system and in the app. Volumes are up and everything else seems OK.
I've uninstalled and reinstalled with a reboot in between. No change.
Everything is upto date. No updates to do and lost as to how to fix it
Help?!
17 REPLIES 17
CameronT
Champion
Hi @Diamond-HeartVix,
Do you have power saving functions enabled?
DiamondHeartVix
No, I don't. Also, both fb and fb messenger are allowed to run I the background
CameronT
Champion
Under the app optimizations (Settings > Battery > Options (3 dots top right) > Battery Optimisation > Apps) try ticking Facebook Messenger in here.
DiamondHeartVix
I don't have that in my 3 dot options
CameronT
Champion
My apologies, it will be the power saving exceptions.
DiamondHeartVix
Ah, yes, I'd found that already. It's ticked. Still not fixed the notification issue.
Any other ideas?
SpyrosFgs
I have the exact same problem. Sometimes notifications come but some others I have to open the app to see if the person I was talking to sent something.
DiamondHeartVix
I'm glad it's not just me. I've reported it to fb. I don't know if it's a messenger problem or an oreo problem. It was all working fine before updates, but everything updated at once so I don't know which update caused the issue.
It's so frustrating as I'm sure you know
SpyrosFgs
I think it's an oreo thing. When I press the home button and let messenger open open in the backround, I don't get notifications and I have to open the app again to see if someone sent me something. When I swipe the app to close it and not let it open in the backround, then I get my notifications all the time.
