App Solid Explorer won't recognize SD card on xperia XZ1. I have tried everything and nothing helps. Other explorers have no problems with recognizing SD card (X-plore, File Commander, Total Commander, ES File Explorer - have tried them to see if they have the same issue).
On Android Lollipop 5.1.1 is no problem with Solid Explorer recognizing SD card.
The other thing is that I can't connect to my pc via Wi-Fi. Solid Explorer finds computer, but it isn't possible to connect to him. That problem with connection to pc is in the other explorers also, except by Total Commander, with him works everything normal.
