Problem with tethering/hotspot
fgselcuk
I have new xperia xz premium, I had previously z2 model and never had tethering and hotspot problem, called my network Vodafone, they replied problem is because of my phone, when I connected to my phone with my notebook I have DNS problems.
Please send if anyone has any suggestions
20 REPLIES 20
kapcus
I am facing identical problem, with identical phone and network operator.
ping 8.8.8.8
works, but
tracert google.com
does not work on connected client
what i have tried already:
- restart phone
- restart mobile network settings
- remove APN and via configuration sms add them again
- change hotspot settings
but without any success.
android version is 7.1.1., phone model G8142
any suggestion ?
KRUP
Ihave same problem. Today update firmware but still same. Not work....
Any info.?
kapcus
solved!!!
This can be fixed permanently using the following procedure (UPDATE: no root required):
  1. Enable developer mode (Go to Settings -> About phone, and click on the build number until the developer mode is enabled).
  2. Enable USB debugging under Settings -> Developer options
  3. Connect the device with a USB cable to a computer with the Android SDK platform tools installed
  4. Start an adb shell: adb shell
  5. In the adb shell, run this command: settings put global tether_dun_required 0
Safs
This solution works for me too!
Thanks to kapcus!
pt60
Hi kapcus,
Thanks for your post on fixing problem w tethering on XZP. I have now the same problem. Is the last character in the settings command O or 0 (zero)?
Thanks very much!
profile.country.PL.title
najodleglejszy
@pt60 it's a zero.
pt60
Thanks very much. I did it. I hit return after I typed the command. Then I closed the CMD window. Is that all or did I need to type any other command to close the session?
Thanks!
iBoss
hello,
im having the same issue, and it still persent even in android oreo 8.0.0  - 47.1.A.5.51
i did factory reset, xperia companion repair, and it's still not working....
is there any other solution or you think it's a hardware problem?
stanlykubrick
Did you try the ADB procedure listed above in this thread?
