Salve,
Chiedo aiuto per un problema.
Ho accidentalmente rimosso dalla schermata Home l'icona di accesso a tutte le App, così riesco ad aprire solo quelle presenti nella schermata Home. Dove trovo quedt'icona, per poterla rimettere dov'era prima?
Hello,
I ask for help with a problem.
I have accidentally removed from the Home screen the icon of access to all the Apps, so I can only open those present on the Home screen. Where can I find an icon to put it back where it was before?
gt
Hi @Mauro77 ;
First of all as this is an English based Forum post all your questions in English so everybody can help you.
Regarding your specific question try long pressing on empty space of home screen>press settings>disable the option "Enable swipe up", now you should have back the icon for accessing all apps.
