ringtone sms /notification
Ironjoy
Good evening
I want to have a different ringtone between an SMS and a notification on an XZ1 how to do and is it possible
Thank you in advance
cordially
Bonsoir
Je désire avoir une sonnerie différente entre un SMS et une notification sur un XZ1 comment faire et est-ce possible
Merci d avance
Cordialement
Uliwooly
@Ironjoy
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Just open the messaging app > menu > settings > notification settings > change the ringtone
