Hello Xperia Support,
Below are some problems I encounter in my Xperia XZ Premium (8.0.0, 47.1.A.5.51)
1. In Email app, if an email lacks "Date" data in its header, the date of the email will be displayed as 1/1/1970. Email app should be able to retrieve Date info from other email header field (such as "Received" field).
2. In Clock app, Seconds can't be displayed. And there is no Second Hand in the Clock widget. I want to know the seconds.
3. In 7.1.1, there is "Actual running time" which shows the actual running time of the phone, but it's gone in 8.0.0. This info is useful and should not be hidden.
Will these be fixed in the next update? Thanks.
I'm not sure about email app, but otherwise i think those are not bugs. Sony (or Google) has simply desided, that second hand/display is not needed anymore. Actual Running Time is there, it's only moved different place. You can find it this way: Settings > System > Infomation about the Phone > Status.
My Phone language is set in Finnish, so i have translate header names. So in English version they may vary. Hope you understand.
@Harry_1990 you can enable seconds for the status bar clock if you want. to do that, pull down notification panel, then touch and hold the Settings icon (little cogwheel) until you feel a slight vibration. then go to Settings > System > System UI Tuner > Status bar > Time > Show hours, minutes and seconds.
