The quality of Sony XZ1 camera is worse than the old smartphone for $ 100
The followin is the photo I made today (I did many photos, but all of them are failed by Sony XZ1 camera). Sony support I would like to see your comments on that ......
Please take a look on this area on above photo. It lost ALL details, the photo is totally blurred.
The following is the photo made by $100 old phone. Do you see the difference??? I think it is much much better.
u should compare the photo taken from same direction. Ur photo taken from old $100 phone doesnt have any backlight.
I compared a lot of photos and they shows that problem. It is the fact that Sony XZ1 noise reduction blure all details. There are many compaints about that in the internet.
And even if we will not compare do you see quality of Sony XZ1 photo? It is all blurred...
I think you're right about this blurring effect the software brings.
Nevertheless, try to be a bit creative and learn to live with the properties of the camera to achieve the best results.
Try to make your Sony photo again by pointing in several directions.
- point a bit to the sky, half press the camera button, point to the center where you are aiming at and press
- point a bit to the ground, half press the camera button, point to the center and press.
- aim at the center and press
You can achieve the same by tapping on the area of the screen where you want to focus.
If you want to achieve more, then read a bit more over here.
Lastly: a phone will never win from a DSLR
I read the link you provided
From panoramic views to close-up photos. Superior Auto mode works best in situations where the lighting conditions are good and you just want quality results without having to manually adjust any settings.
Above is not truth. Auto mode is not usable.
It possible to make good photos only in manual mode.
bad default apps, lost details. in comparison with third-party applications
Let's stop defending. We all know that Xperia cameras are very poor. Just admit it.
Not sure who is defending the poor camera...
Maybe you should know. ...
Here's a photo using my XZ1. Even with high compression(to be able to post it),the photo still looks good. Please check 2 OR EVEN 3 times b4 posting bs kk?
