Type-c Dock
Andy0380
Type-c Dock
I want use my XZ2 Premium with type-c dock.
Is it possible?
Jonas
Master
Hi @Andy0380, welcome to our community!
Are you referring to a charging dock as the one on the link below?
https://www.sonymobile.com/global-en/products/accessories/usb-type-c-charging-dock-dk60/
That one works just fine with an Xperia XZ2 Premium, or any other Xperia device with a USB Type-C port.
I hope that answers your question and let me know if I misunderstood something! Slightly_smiling_Face
Andy0380
Hi thanks for the answer but I would be interested to connect my sony xz2 premium to the TV
Ciao grazie della risposta ma a me interesserebbe collegare il mio sony xz2 premium alla TV
@Andy0380
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Jonas
Master
Hi again @Andy0380!
Oh, I see!
The Xperia XZ2 Premium does not support MHL, so you will need to either cast the content from your device using the cast function to a Chromecast, or directly to your TV, depending on if it is supported.
If your TV supports Screen mirroring based on Wi-Fi CERTIFIED Miracast, you can use this instead.
You can find some additional information on the link below.
https://support.sonymobile.com/global-en/xperiaxz2premium/userguide/mirroring-the-screen-of-your-dev...
I hope that helps! Slightly_smiling_Face
