USB Ethernet connection lease refreshes every 2 hour
Nymad
Is there way to incrase Ethernet Lease time?
I know how it is done with routers but i havent found option to do it for shared phone connection.
Jonas
Master
Hi @Nymad, welcome to our forum!
There is no setting in the device that will increase the lease time when using USB tethering, or when using tethering/hotspot in general.
Unless I'm mistaken, this should be controlled by your operator as you only share the Internet connection via your phone to your computer and when you aren't using a portable hotspot, the device acts more like a modem than a router and the computer should get an external IP address, and not for example, a 192.168.0/1.x IP address.
I hope that helps!
